Almost thirty years, I've been wrenching on cars. This past weekend, I exceeded my personal record for "oh crap" moments. We're talking about surpassing the Chevy Nova drifting on a dirt road behind the police station incident of 1998 here folks.
I bought a '94 land cruiser for a song a few years back. I knew it had a bad engine but I bought it anyway thinking that I'd just rebuild it over the winter. I ended up swapping in a running engine off craigslist and everything is life is good. Drove it for a year or two and got the rest of it running the way I wanted it to (thanks to the help of many folks on this forum). Then one day, I come out to the garage to see gallons of coolant on the ground, I had a cracked block.
No problem I think (after cussing those fools at Toyota for not making the block stronger). I have the old busted engine that I can rebuild the way I want. I can take my time and do it right and make sure it will run for another 200k miles. So starts my winter of 2018 rebuild. I put a ton of time into making sure it's done perfectly. No shortcuts, full tear down, block got hot tanked and machined 0.020 over. When I pick it up from the machinist, he notes that they cleaned up the block and left the oil galleys open so I can clean it before I assemble it (as I requested they do). I get home and make a new checkbox on my todo list. REINSTALL OIL GALLEY PLUGS.
After 2 months of continuing to build up the engine and get all the rubber vac lines replaced, parts media blasted, painted, etc..... I must have lost track of that TODO item.
This weekend my wife and I went to start it. Man it sounded good. I'm looking at the engine to make sure everything is good. Then all of a sudden, hell broke loose. Turns out that those pesky oil galley plugs need to be installed or all the oil gets pumped right onto your garage floor. I go to Mud to see if anyone else has ever had this problem and I find a description in a thread of exactly what I have happening. Oh crap, I forgot to install those plugs. My garage floor is flooded with oil and I'm looking at a few solid days of wrenching to get that timing chain cover off. Turns out it only took about 5 hours to get down the timing chain cover off. I managed to do it without pulling the oil pans saving me a ton of work and a lot of frustration.
So, the purpose of my thread. Anyone know where to get replacement oil galley plugs for a 1FZFE engine? I'm trying to do it in the car, if I had it on a stand and I could clean up everything, I'd just thread them with a pipe thread and put plugs in. I'm hoping that someone had a hammer in plug or ball bearing source that I can use so I'm not cutting threads.
Thank you.
Thank you.
