Dome light gremlins (1 Viewer)
Seattle
I’ve been fiddling with this f*****g dome light for almost 5 years now. Replaced the original festoon bulb with a small 4-pot LED board. Every other time I open the door, it lights up dim or flickers. I’ve replaced the LED unit twice, cleaned all the contacts on the switch, cleaned the harness connector, and even run a second ground wire to the chassis. Still acts up in both DOOR and ON positions. When I bang on the ceiling or wriggle the light housing, it often lights up fully, which makes me think this is a connection issue.
Anyone else have the same issue and managed to solve it?
MTB Land Cruise
Los Angeles
I had kind of the same problem, did the same cleaning, Tested with an OEM Blub and LED and still had the issue. Also found that the driver's door switch was not working. So, i just installed a new assembly and new switch. Problem(s) solved.
Part # 81240-22070-08, Interior Dome Lamp Assembly (Front)
Part # 84231-28010, SWITCH ASSY, COURTESY LAMP (FOR FRONT DOOR)
Spook50
My daughter likes Stitch
Supporting Vendor
Spokane, WA
Yep those switches get touchy after 30+ years. I recently cleaned both front door switches, smeared a touch of carbon grease on the point where the wire lead contacts the housing, and reinstalled with some copper (for the sake of conductivity) anti seize. Works perfectly now.
db3
SF East Bay Area, CA
I have had similar problems with both the original and a new replacement dome switch. The problem was much worse with LED bulbs, but I still had occasional issues with an original bulb. I finally determined the problem was the staked rivet connections to the bulb clips were loose, the result of poor workmanship. My first thought was to solder them, but realized this would probably melt the plastic, so I choose to drill out the rivet and use a 2-56 stainless steel machine screw to secure the bulb clips.
Gun Runner 5
KI4CMQ
Thomasville, GA
P.M. sent. (LED dome light kits)
Spook50
Supporting Vendor
Spokane, WA
Not a bad idea. Was this on an aftermarket replacement or an OEM replacement?
Southern Colorado
My dome light is flaky on cold days when I open the rear door because the rubber bellows that protect the door switch are old and stiff. If you grab the door pin switch (the rubber bellows) and pull out, the light comes on strongly. I just chalk it up to 'old truck charm' and live with it.
