Check Denso website or even Rockauto also try Partsgeek.
Resurface an A/C clutch is something i never heard of, i'm old but maybe not that old.
Is that just a matter of testing with a multimeter...one probe on the positive prong on compressor connector and ground other probe to see voltage?
Looks cheaper to buy the magnetic clutch assembly. $123 vs $398 on Toyota parts deal, if I'm looking at the right part.@BullElk Did you shop around for a magnetic clutch assm. versus a complete compressor? I looked around and i think the best you can get is a Denso unit from Rockauto there is no listing for any magnetic clutch unit with the exemption of Toyota, Denso don't even list it on their website and i didn't even see any aftermarket unit i didn't go very far on this i just looked at the popular sites.
@BullElk If you are going with the used route bench test the coil while your at it and flush the compressor if you decide to install it. If i'm not mistaken your compressor take a ND_8 or PAG 46 oil flush the compressor with at least 2-3 ounces hand spin the front of the clutch several times and then dumped it if you have a clean plastic or glass container check the oil for signs of any metal particles they tend to sit at the bottom of the compressor. Since the system is not completely empty just add about 3 ounces of oil in the compressor before you install and hand spin the front of the clutch to circulate the oil. Let us know the outcome.
