Does OME Heavy w/o extra wt. = rough ride?
Indianapolis
I am about ready to pull the trigger on an OME lift but I am stock as far as bumpers, sliders, etc. for the time being. I do plan to add these probably later this year. I have read posts that say the mediums and the heavies have the same spring rate and the only difference is the heigth of the springs. If that is the case then it seems the heavies wouldn't ride any rougher than the mediums. The only difference is the heavies would give a higher lift without the added weight. Is my assumption correct? Thanks in advance for your comments.
I ran the 2.5" OME heavies and they improved the ride and handling of my 1993 LC 100%. I have since added; 285 Firestone MT"s, an ARB winch bumper, Slee step sliders, and a couple of skid plates, but my truck rode fine without any of the "after lift" additions. I am hoping to add a rear bumper/tire carrier and winch soon. If you have similar long term plans I would definately go with the heavies as the weight of the accessories adds up quickly. Hope this helps. YMMV. Scott
I just installed J's up front and heavies in the rear and so far loving the ride, no vibes at this point :D Only additional weight so far is sliders & skid and no problems here... If you dont want a stinkbug look you will have to mix springs or add spacers...
What did your caster correction some out to, and did you have to adjust any suspension geometry in the rear? Seems like a pretty light 80 series with Js and heavies would get close to fitting 315's without tearing anything off.
-----Nate
if you are definitely going to add those items then i would say go with the heavies. otherwise. you will find the ride rough. depends on what you are used to of course but it is definitely more jarring, to me at least, with the OME heavies if its not loaded down. the only time i really like them was when i had the ARB on the front with all the tools in the back and a few passengers. then it was a dreamboat.
-----Nate
Nate I would suggest a search on this. It has been covered a ton and of course there is no rock solid answer. It varies from truck to truck some say but the general rule of thumb is if you are going 4"+ you will need panhard correction, maybe even control arm correction and def. castor correction. again, please give a search for this topic.
-----Nate
Peepers is right about tons of opinions, but in my experience it worked out fine w/ Light being the key. I ran 35's on the j lift and still have my flares but only had sliders and an IPOR skid and stock all around w/out 3rd row. There was the very slightest decel. vibes and ome standard bushings were not enough CC (.8 and 1.2) id think about the blues or plates. and of course your results may very from truck to truck.
Peepers bud, I know I'm right there with 'ya on that one :beer: (I followed the series of W.E./slee threads as well on the spring/caster issue). I was just curious if FL80 got away with this combo without the aforementioned stuff or if he simply neglected to mention it.
I was told the same thing by a rep at Slee regarding the spring rate and height. Only difference is height in order for loaded expedition rigs to maintain proper off-road travel. I have the mediums in the rear and love the ride...I don't have REAL expedition gear. I don't have any stink bug, but I added Slee's front spring spacers. I have a stock rear bumper but keep alot of crap in the rear of the vehicle...I haven't had any complaints with the mediums in the rear thus far...my .02
A longer spring with the same spring rate will have a higher effective rate. That is why unloaded OME heavy do not ride as well as OME medium, which don't ride all that well on their own to be honest.
I think the "harsh ride" bit is overdone, personally, but if you want a system that will ride like buttah completely unloaded with no stinkbug but still handle moderate weight excellently (bumpers, passengers, gear, etc.) get the FOR kit. That's exactly what it was designed for, and it will handle 35's perfectly out of the box.
I don't mind the stinkbug look. Not sure why that is such a big deal to everyone. Stock has that look. Right now my stock height is an inch higher in the rear and I wouldn't want it to be lower in the rear than the front with extra weight or towing something. On the ride issue, I don't mind a little of a truck-like ride. I just don't want the wife complaining about it when she rides in it. Comments have been much appreciated so far. Anyone else?
I have the J's and L's on a 94 Lc and it seems to be just fine. I also am running 35 tires and I do get some rub when flexing but not enough to worry. I also have the stink bug look but have ordered the metal tech spacer for the front. I am totaly satisfied w my setup. Just something to think about. I say go big...
-----Nate
Nate, I actually only got my lift (J's&L's up frt/863&N74E rr) on this past week so it hasnt been to the shop yet and I need parts still before alignment is done... I do plan on doing caster plates but still need to purchase them. I also need to buy a new tie rod, so Im buying a bud-built rod & drag link & new TRE's... I also have removed my sways for the time being but will probaly go ahead and space them so I can put them back on. When I have accomplished the above if I have a problem I will look into additional items that maybe needed, but at this time even with no caster plates,a bent tie rod and no sways my truck still drives straight and feels safe. I have had it up to 80 on the freeway 3 times and yes it is a little looser than before but what do you expect when you lift a heavy vehicle, remove sways and have a bent TR:steer: :doh:
I measure 23.5" on the rear and frt ps & 23" frt ds but I imagine they havent settled in yet probaly only put 100 miles on it.
Prelift I had 20" all the way around except 19.75" on the ps rr.
Heres a pre & post pics ( my driveway does slope at a decent angle towards the street) so on level ground I am almost perfectly level with a very slight stinkbutt
864 springs ride like an empty pickup truck if you are empty. The more gear you carry, the more cushy the ride.
