doea anyone make rear disc conversion kits?
Discussion in '60-Series Wagons' started by djanis99, Jul 7, 2005.
  1. djanis99
    djanis99
    92
    1
    Mar 31, 2004
    Hey all, I am having probelms with my rear drums. Basically they are not adjusting. Ihaven't had it up in the air yet to figure out why but I am guessing it may be related to the seized parking brake cable. I need to fix this in order to pass the MD state inspection. I was thinking about doing a rear disc conversion to solve this problem.
    Does anyone sell kits for rear disc conversion? Does it have a parking brake on it?
    Thanks,
    Dave
  2. Tinker
    Tinker
    2,865
    9
    Apr 15, 2004
    Larkspur, CO
    Dave -
    Your bellcranks are probably siezed - my 84's were, preventing the auto adjusters from working thus not allowing the shoes to press against the drums fully. Put the rear axle on jack stands & take 1 side apart at a time; remove a bellcrank housing, drive the pin out & then the crank, sand the crank & the housing, & re-assemble with good, stiff, synthetic grease.
    After you get both sides done, adjust the brakes manually (FSM shows how). I learned (before auto adjusters) to crank 'em up as far as you can & back each wheel off until you just hear one "sshhh" per revolution on each side. Now the auto adjusters will work.
    Properly adjusted rear drum brakes are more than adequate. If you still have the need for rear discs, check out http://www.tsmmfg.com/2491.htm
  3. Cruisergreg
    Cruisergreg
    1,846
    3
    Jul 20, 2003
    I think rear disks on a 60 are a wasted effort. You'll probably end up with more problems than you'll solve. FWIW, I think MAF makes a conversion kit using some Caddy brakes.
  4. Overlord
    Overlord
    485
    Feb 19, 2003
    Wasilla, AK
    IMO, they are worth the effort, although I'm still running drums. They're worth it with big tires, it takes a lot of effort to stop these rigs while running larger than stock tires. I also would like disks for when hill climbing and don't make it. The drums don't have the same stopping power while going backward.
  5. Overlord
    Overlord
    485
    Feb 19, 2003
    Wasilla, AK
    Oh yeah, another good reason for RDB is when one breaks a rear axle, it helps to keep the wheel on. Although a FF axle is better. Now a FF with rear disks would be sweet on a 60. Half way their myself. :)
  6. zcruiser
    zcruiser Needs monitoring
    1,205
    12
    May 7, 2005
    Hillsborough, NC
  7. WALoeIII
    WALoeIII
    451
    2
    May 18, 2004
    Seattle, WA
    I would think that completely converting to a FF rear would be worth if if you are going to do a conversion, you are also able to use FJZ80 E-lockers!
  8. stinkyfj60
    stinkyfj60
    1,344
    3,387
    Apr 22, 2004
    Roodepoort, South Africa
    I remember reading that Lance at Iron Pig Off Road is working on a kit too. I have not seen it on his website but if anyone knows his progress I would like to know about it.
    Jason
  9. HZJ60 Guy
    HZJ60 Guy Tank Buster
    2,356
    4
    Sep 11, 2003
    Seattle area
    I have rear disks. I got them when I bought some kick ass set up axles from the master Peter Straub. Ok so I didnt have to set them up, but I just cant think of a time when disks arent better than drums. From performance (wet and dry) to wear, to maintenance, to replacement. Disks are better. I (well Rob added) added a 1994 FZJ80 master cylinder into the mix to give propper power to the rear end.
  10. Spook50
    Spook50 Get ready
    5,025
    993
    Feb 16, 2005
    Spokane, WA
    I'll be doing this before doing the SOA. I plan to order the TSM kit with Eldo calipers.
    Someone please correct me if I'm wrong, but the only things that're different for discs between the semi float and full float on a 60/62 are the brackets and the hole size on the rotor, right?
    Hey HZ60 Guy, does the MC you got have any proportioning valve in it at all?The minitruck MC I got when I upgraded my fronts has no proportioning valve, so I had to adjust the LSPV quite a bit to get my rear drums to work again.
  11. Cruisergreg
    Cruisergreg
    1,846
    3
    Jul 20, 2003
    I won't argue that point. But watching a friend with a RDB 60 have multiple problems with them made the conversion unattractive.
    The dirty little secret about rear brakes is that they really (on pavement at leat) only account for about 10% of braking capacity - they are more for directional control when stopping.
