- Joined
- Jun 6, 2005
- Threads
- 80
- Messages
- 1,482
- Location
- Jacksonville Beach, Florida
- Website
- exitoffroad.com
After many years of requests, Dobinsons have finally come out with bump stop extensions to run with the 4" and 6" length shocks they offer.
BS59-608 - Dobinsons 80 Series Front Bump Stop Extensions Kit (1.0-2.0 in)
BS59-609 - Dobinsons 80 Series Rear Bump Stop Extensions Kit (1.0-2.0 in)
Both sets are in stock and available now from ExitOffroad.com. Click the product heading just above to go right there.
Both sets have the same main features and benefits:
- Suits all Toyota Land Cruiser 80 Series from 1990 to 1997
- 1″ (25mm) extensions stackable up to two per spot for a total of 2″ (50mm) of thickness
- Durable Solid Steel Spacers
- Sold as a Kit for inner and outer front or rear bump stops
- The inner goes inside the coil spring on the inner bump stop
- The outer goes between the mount and the bump stop on the frame
- Space down your bump stops to prevent shock bottom outs at full compression
- Keep your tires out of your fenders if they’re oversized by spacing down the bump stops
- General bump stop extension guidelines (will vary based on brand of shocks and bump stops used)
- Dobinsons 0-3″ lift shocks: Extensions are not necessary, unless running oversized tires
- Dobinsons 4-5″ lift shocks: Front needs about .5″ of bump stop extension, rear needs 2” of bump extension
- Dobinsons 6″ lift shocks: Front needs about 1.5” bump stop extension, rear needs a 3” extension or 2″ extension with extended length bump stops
