Do you measure gearlube and such?
Discussion in 'Chit-Chat' started by mabrodis, Aug 2, 2005.
  1. mabrodis
    mabrodis
    1,150
    4
    Mar 22, 2004
    Castle Rock, CO
    So when you change diff gearlube or t/c gearlube do you actually measure the amount, or just fill it till it comes out. I have always just filled till the oil was coming out the fill hole. However, I was just thinking tonight that that is probably not the correct way to do it. But if not, then why is the fill-hole there, and how did they determine it needs exactly 1.9 quarts for example when filling it till it comes out the fill-hole is about 2.2 quarts or so (referring to the transaxle on our Echo)...
    Just curious...
  2. Stone
    Stone Moderator
    3,130
    8
    May 13, 2004
    BC, Canada
    Actually, filling diffs, trannies and t-cases with gear lube until you can just feel it touch the bottom of the fill hole is the proper way of servicing those components (as far as I know). The only stipulation would be that your vehicle is on a level surface so that the level(amount) of the fluid inside the component is right.
  3. cruiseroutfit
    cruiseroutfit Supporting Vendor Moderator
    7,677
    4,417
    Jan 9, 2003
    Utah
    Fill it til it comes out... :D, on axles that have been rotated, park them on a ramp or slope that counteracts the rotation... or just overfill and shove the plug back in :D
  4. mabrodis
    mabrodis
    1,150
    4
    Mar 22, 2004
    Castle Rock, CO
    Cool, thanks guys...the Echo's enormous tranny/transaxle combo holds 1.9 quarts, or maybe 1.8, anyway, I put in 2 quarts exactly, it's close to full, but not pouring out yet...but then I remembered the front is up 3" on little ramps I made, and the fill is towards the front.
    :cheers:
  5. nuclearlemon
    nuclearlemon not an addict Moderator
    16,070
    Media:
    87
    Albums:
    4
    885
    Jan 30, 2003
    meh-ico, colorado
    i fill em till it spills out.
    on my soa rear, i welded the original bung and added one higher up...much higher since i run oil in the rear hubs also.
