Ok, I'm waiting to hear what is wrong with what I've just done...
First of all, if you didn't know, the iPhone has a very accurate-repeatable (to a 10th of a degree) accelerometer built into it. There are several apps that measure angles using this. I use one called clinometer. I calibrated the phone and then started measuring.
For background, my rig has longer shackles (5" pin to pin), and some kind of after market spring lift that gives somewhere around a 4" lift total. I have a bit of wander at highway speed so I thought I'd look into the caster. There are no shims on the springs so I expected to find that I have negative caster.
I pulled the rig front first into my garage, cleaned the floor and measured the slope of the floor at the wheels using the phone and a 4' straight edge on the floor. One measured +0.5 degrees and the other side +0.7. So I've got about a half degree slope going down toward the door which would make sense to carry any water out of the garage. Then I cleaned the crud off the knuckle spindle where it attaches to the knuckle. I measured using the machined flat on the knuckle spindle on both sides getting -4.5 and -5.8 respectively (the phone is lower toward the front of the vehicle). I repeated these measurements 3 times and got the same results.
This would say that I have -5.0 and -6.5 caster. I know this isn't rocket science, so my thoughts were to get a pair of 6 degree shims and mount them fat side forward.
