Do I need a knuckle rebuild and a water pump?
Michigan
Visit site
Hi is this just gunk or both soup? It drives fine from what I can tell.
I have been having the noise in the video and today I looked under my car and noticed the metal was wet looks like water doesn't have a smell, does that confirm its a water pump leak? Final question can I drive across the country with the front axle needing a rebuild and if it's the idle pulley wait till I get home to get that repaired?
The Saratoga slums, CA
Visit site
From your picture, it looks like at least one stud on the passenger side steering arm has backed out. That could cause some of the leaking at the knuckles. It can also cause bearing wear in the knuckle. I would check the torque of all the knuckle studs and nuts before driving anywhere.
The leak under the radiator should be traced and fixed before driving cross country. Is it radiator coolant or transmission coolant?
Michigan
Visit site
Not sure it was very clear and didn't have a smell I think the red hue might be from rust.
Socal
Visit site
from your vid, wp looks dry. confirm there is leaking from the wp
The wetness could be leaking trans lines to radiator, coolant leaking, oil leaking... power steering cooler leak - the ps cooler hardline looks wet.
the sound could be a bad pulley, could be worn belts, bad alt or wp...
Michigan
Visit site
I did notice that the ps does have a little leak.
Michigan
Visit site
Your balls are dry. Luckily they make an ointment for that.
Based on what mine looked like when I bought it, and how much grease I've added, and how yours look, I'd add 150 to 200 cc's of moly grease to each side.
on a clip to paste it in
Hahaha I'll definitely lube them up before setting off.
Olathe, KS, USA
Visit site
The noise in your first video is "loose" or worn belts on the alternator. You can tighten them with a 14MM deep well socket and a 12MM ratcheting combination wrench. Takes about 15 minutes. Don't break off your radiator nipple in the process.
Michigan
Visit site
Yeah the shop confirmed that thank you.
