COYS
The only u-joint you can change is the front one.
So can I use the OEM 04371-60070 front u-joint?
I can definitely say that this lubrication schedule is a bit exaggerated. I lubricate my DC shafts by removing them from the cruiser every oil change at 5k miles and haven’t had any problems with the center pins. My DC joints are not Toyota and use the Spicer Life Series joints which also have worked out well. The only disappoint thus far is that the 1310 sized stuff is a little light weight for the rear shaft of a loaded 80 climbing rocks in 37” tires and I ended up with less than a press fit with regards to the bearing caps in the cages but never a broke hard part. This came up after five years so I don’t exactly consider it a huge issue considering the way my truck gets used.Also realize that a DC shaft will require proper lubrication every 3000-ish miles. Otherwise, they can come apart on the interstate and wreck all kinds of stuff.
