no lift springs yet, SOA eventualy, with 3" blocks how much lift will that be?
don't waste your money on a body lift. Save you dollars for a suspension lift.
Body lifts are for Jeeps.
And that's all I need to say on that subject.
~John
Dont you like that big gap and exposed chassis look?
I thought it was all the rage in North America
Scary Steering!
and the headlights are inline with the bullbar etc
If you don't raise the bars to match the body lift, of course it is going to look stupid.![]()
careful is what i will say...
a small body lift can actually look nice and practical and cheap
but this also means longer bolts going through the block. the longer bolts will have more leverage placed upon them when cornering, accelerating, stopping, sidehilling. you need to keep an eye on the bolts for loosening and stress. if you feel that floating feeling, stop immediately and check out why. your brakes and steering can be affected.
the one truck i did we welded the blocks to the frame and used the factory mounts and bolts to reattached the body.
as for how much lift? you still will need the rubber mounts so what ever blocks you use will be the lift you get.
