Hey guys, I've started to change the timing belt on my 2000 LC myself this week and am running into a few issues with it, so I'm wondering if there are any others on here that have done this job that can give me some advice? I've done a few T-belts on various cars but this is the first time on the LC.
I have removed the right timing cam cover and the tensioner and am attempting to remove the left timing cover but am running into problems there and a few other spots.
Problems:
1. I have removed the 2 bolts holding the upper thermostat housing onto the top of the water pump but the thing will not budge loose. I have tapped it with a hammer to try to get it loose but am afraid to use any further force in case there is another bolt somewhere? It's really stuck on there. My understanding is that the square mating service to the water pump is just RTV and then the circular O-ring into the engine block opening. ?? It's not moving AT ALL.
2. The LH timing cover with the cam position sensor wiring will not come off. ALl of its bolts are off and it is loose, but something seems to be catching it at the bottom where the cam sensor is. I removed the rubber grommet around the cam sensor wire on the cover. I can't get the external connector for that sensor to come off the cover so I can leave the sensor and its pigtail there. Is there a trick to getting that thing off the cover without breaking the plastic mount?
3. I can't get the fan pulley bracket off the front of the engine because the left hand side is blocked by a bracket holding electrical connectors for the A/C conmpressor. I've removed all the bolts holding the bracket including the 2 side bolts that go into it from the A/C compressor itself, so the fan bracket is definitely loose. There are no more bolts holding it. However, I don't know what to do about this electrical mounting bracket which seems to be rivetted to the A/C compressor? Is it necessary to remove the A/C compressor to clear this electrical bracket?
any help is appreciated.
thanks
davemac
Problems:
thanks
davemac
