1st post.
I recently pulled the air cleaner housing from my desmogged ‘84 2F engine and forgot how to put the vac lines back together. Thanks to this great site I figured out how things are supposed to be. My current set-up is a manual choke Rochester carb (7012452 used on 55-58 Chevy) without any of the vac ports found with the Aisin carb. The vac line from the intake manifold to the VCV was cut and sealed off so I don’t think my dizzy is properly ventilated. I’m considering reinstating the VCV but I have two questions:
- Do the unwanted fumes that fill the dizzy come through the dizzy/engine seal or the vac advance lines originating from the intake manifold?
- Why is the VCV even necessary (ie, why not just run a vac tube straight from the dizzy to the air cleaner housing)?
