What would cause my timing not to "hold"? Each time I get into the truck and start it, it runs a bit differently. I check the timing and it has changed. The hold down clamp is tight so the distributor isn't moving.
So far, while working on tuning my 69 Fj40 and I have replaced the points, (gapping them to .018") cap, rotor, wires and plugs. I have a Holley carb on the rig and have set the idle, float level and mixture. I get it running just "right" and then when I come back to the truck later the timing has changed. Do I have gremlins playing a trick on me or what?
Can the distributor itself go bad?
Any help would be great.
