Mace said:advance is what it is all about.
Basically, you adjust how quickly the advance happens in your dist.
Most of the time it is a domestic adjustment (kinda hard in a toyota dist)
I would disagree on the impact of timing on a 2F. My experience has been that this motor is VERY sensitive to timing, much more so than other motors I've had.Mace said:depends on the motor. I see no reason to recurve a Toyota Dist..
The distributor has an advance curve. A combination of centrifugal weights (RPM sensitive) and vacuum canister (load sensitive) change the timing. For any given RPM and load, there is an ideal ignition timing point that gives max efficiency (best MPG and power).meatloaf said:I was reading the carb rebuild post...One or two threads mention the 'dizzy recurve'...what does this mean?
Thanks in advance,
Meatloaf![]()
