Distributor Cap & Rotor + Spark Plug wires + Spark Plugs + Setting Ignition timing
beetagh
Forever Learning
Round Rock, TX
Website
www.youtube.com
Went through replacing the distributor cap, distributor rotor, distributor o-ring, spark plug wires, iridium spark plugs, and setting the base ignition timing. If you need a visual to walk you through the steps if it's your first time here ya go. Enjoy!
Replacing distributor cap and rotor:
Replacing your distributor O-ring:
Spark plug removal and installation. I went with the newer Iridium plugs:
Spark plug wires replacement:
And finally, how to set your base ignition timing. Some people set theirs to 10 degrees and other settings. Factory setting is at 3 degrees so that's what I went with:
