i could have hooked you up with a used cooler, that sucks man. best of luck to you.
Don’t forget to order gaskets. Let me know if you need part numbers. Props on the title change.
I wouldn’t run distilled water in a iron block for a extended period of time without coolant to prevent the oxidation of the block and introducing more junk into the radiator. Just letting it sit overnight will cause rusty water.
