standard x-over would be fine, but the behind the axle tierod is way cooler the heims are illeagal because they are not DOT, but the heims poliece wont pull you over i promis . and they are plenty safe/strong if you buy quality ones.
2.5 inches: The steering correction kit/perches provide 2.5" of lift and the springs provide another 1.5" for a total of 4" in the front, which matches the rear lift of 4".
Shims were not necessary due to the fact that when you flip the springs the angle of the diff is correct. The correction kit came from BTB (see pic) and the springs are Skyjacker.
Randy
_________________________________________________________
"ArmyFJ So do you mean 2.5 deg? or 2.5"? You just use shims right?
Matthew"
