OK.....Just got through doing a disc brake conversion on the front axle(67 FJ40 w/SBC, ball and claw axle, JTO front disc conversion, Geo Metro booster, wilwood proportioning valve). One problem, I have to pump several times to get a firm pedal. I know this has been discussed ad nauseum but I have done everything I can think of and read on this forum. 1)bled, bled, bled, and rebled the system 2) adjusted the rear drum brakes (till tight and then backed off three clicks), 3) checked for leaks (there are none) 4) checked pushrod length. The set up is this Geo Metro booster and M/C, front lines run to the calipers which are GM, rear line runs to the Wilwood proportioning valve and then to the back drums. Now, if I clamp off the rubber line at the rear of the rig (using a wood c-clamp) it brakes fantastic, better than I could ever get it to with the drums. It really hauls it down, with a really light pedal feel. I couldn't be happier with that part of it but when I release the clamp and put the rear drums back in to play I have to pump the brake pedal 4 or 5 times to get a firm pedal. I am POSITIVE that I have gotten all of the air out of the system, and yes I know all about the air trapped in the wheel cylinders problem. I am POSITIVE that I have adjusted the drums correctly. The only thing I can think of is maybe I need a residual valve in the rear drum circuit? If so, 10#s or 2#s? Anything else I might be missing here? Thanks in advance?
