disc brake question
Discussion in '40- & 55-Series Tech' started by 320t, Jul 24, 2005.
  1. 320t
    320t
    73
    Jan 28, 2005
    Tempe, AZ
    Sorry in advance if this has been discussed. Is anybody not running the backing plate when they convert to mini truck disc brakes on a 40? Are they even necessary? Pros and cons of not using the. UR .02 appreciated. Thanks Don
  2. short bus
    short bus
    80
    Jul 18, 2005
    Rain Country, Oregon
    I'm not running the backing plate completely. But I did cut out the inner ring that bolts behind the spindle to keep the distance the same. And also cut off the part of it that the hard line mounts to, and mounted it behind caliper bolts. Tired of packing the backing plate with mud, and rocks. hope this helps.
  3. LC_Hamma
    LC_Hamma The Anti-Leafer
    2,674
    24
    Nov 11, 2002
    Dallas, Georgia
    No biggie, I would route the flex lines close to how the stock setup looks. I would attach a brakeline clip to one of the rearward knuckle felt bolts so your flexline isn't hangin' low.
