disc brake brake line 76 FJ40 Front
house
Broke the metal line that goes from my passenger side caliper to the juntion block on the back of the rotor dust shield having a heck of a time finding one any body have any ideas TIA
Cruiserdrew
On the way there
Sacramento, CA
1-Buy from Toyota-same as FJ60, I think
2-Bend your own-PepBoys has the 3/16 tube and 10 x 1 metric fittings insanely cheap.
3-Bend and flare your own-Classic Tube has fittings that look/seem like OEM. They have a 25 foot roll of 3/16 tube for like $12 and the fittings for $1 each.
4-Soft line directly from axle to caliper. Works fine and I ran like that several seasons.
Kansastitty
Like Drew said, but I think the "short side" is available, but the long side is not.
Bending and flaring is not that difficult.....because I did it on all my brake lines.;) Be not afraid.
GL
Ed
erie pa
went to napa bought 8" line bent it up and screwed it in good luck
MT
I just did this last week, the 8 inch line is just long enough but you need to start the bend right at the nut on the caliper side first. I used a small round srewdriver handle to make the bend as smooth as possible. Buy an extra one while your there, I think it was between $2 and $3. they tried to give me a standard thread first so keep them on their toes.
thecrazygreek
A.K.A. TheCraftyGreek
GOLD Star
Oregon
Best way to bend a tube by hand is to wrap it with a similar OD spring. (Home Depot etc has these for cheap) Slip the tube into the spring and bend away. This will prevent any kinking in the line...
:cheers:
san pancho, ca
pickup a quality flare tool and bend your own...
you'll be surprised how easy it is.
