I've heard VSC beep, but not A-TRAC.
then you havent done extensive donuts/drifting in a snow-covered parking lot. If you spin your tires long enough it starts to get pissed and beep at you, and then it says, HLYCHT STOP SPINNING AROUND aka, steady tone.
So, all of that = no A-TRAC beep, yes VSC/TRAC beep.
No ATRAC beep A beep will ONLY be heard when VSC is active.
Read again. I'm just paraphrasing the owner's manual. If it's wrong, take it up with Lexus.![]()
I'd know that if Hertz rented Landcruisers![]()
I got a front wheel off the ground. a-track light came on, no beep.
**Exactly...no sound, just a transparent system helping you out.
Later on I was flying through the sand. Occasionally catching air and having a blast. And when the vsc light came on, I heard the beep. Which soon went to the long beep, and shutoff vsc.
**Exactly...the beep from VSC tells you somethings going wrong. Then the longer beep tells you the VSC AND/OR ATRAC systems are disabling so to save your Brake Booster. I appologize to Loud as I meant to point this out last night about his quote.
I've confirmed it thru testing for years, atrac will cause beeping...then a steady tone if you spin the wheels.
Also, you're numbers on 100 offroaders is wrong, they didn't make that many in the 10 years of production.
