Always following as most of what you’re doing is in my future.
Yes I agree, makes sense to drive for a while before tearing into the case.I think I’m cruising at +/-2,100 on 35s and 8% overdrive. I would run it with the 4.10 and stock gears first.
Yes I have a factory dial switch that I will be wiring in.I’m interested to hear your review of the Harrops. Will you use the stock locker dial?
So I'm on 4.10s and stock t-case, but have been considering just regearing down to 3.54 - Marks out of OZ sells a kit I've been eyeing. I'm certain my 15-17mpg is down to the engine spinning too fast, so my options seemed to be 37" tires and 3.54 diff gears. What's the t-case reduction gear you've got?Yes I agree, makes sense to drive for a while before tearing into the case.
Thats the same MPG I am getting but I also drive 70-75 everywhere I go. Once you get above the 2,000 rpm mark I think mileage goes to s***.So I'm on 4.10s and stock t-case, but have been considering just regearing down to 3.54 - Marks out of OZ sells a kit I've been eyeing. I'm certain my 15-17mpg is down to the engine spinning too fast, so my options seemed to be 37" tires and 3.54 diff gears. What's the t-case reduction gear you've got?
I have the terrain tamer 10% overdrive high range gears for the HF2AV. I also have the Marlin 3.1 low range gears to get installed.So I'm on 4.10s and stock t-case, but have been considering just regearing down to 3.54 - Marks out of OZ sells a kit I've been eyeing. I'm certain my 15-17mpg is down to the engine spinning too fast, so my options seemed to be 37" tires and 3.54 diff gears. What's the t-case reduction gear you've got?
Yes that is the part I am not looking forward to. When I installed King 3.0's on my ram I was able to droop the axle axle far enough that i didn't need to compress the shocks...no sure If I am going to be able to do that again. In any case I have jacks and a buddy to help out.Speaking from experience you may need to enlist some help (mechanical or otherwise) to help compress the shocks when you install them. I definitely wasn't burly enough on my own and had @treerootCO do it and it's was a challenge for him as well, and the truck was on a lift at the IH8MUD HQ. Can't imagine trying to do it get the shocks compresses while lying on your back under the truck. Floor jack may be the answer. Some series pressure in those puppies.
IMG_7947 by Adam Tolman, on Flickr
Looks good Morgan! Where will the connection be for the air hose? Do you have any concerns with heat from the compressor in that mounting location?
