- Thread starter
- #141
Broken rear swaybar link.
Pretty awesome. So did the axle coil buckets line up with the gm buckets?It drives ,self corrects all the way up to 80. Also crammed the brakes a few times just to test my frame side mounts. Waiting on limit straps and the cure for the 1 ton steering.
I used the oem dodge coil buckets. Just cut them off the dodge welded them to wfo frame plates and welded them to the frame. The Chevy and dodge frame’s are the same width. So it may have lined up with the Chevy shock mount but I'm not sure its been so long... but to get the measurement I just marked the center of the wheel on the fender with at plumb bob before removing the IFS then just lighted the axle up with the string and got my marks that way for the coil buckets. I believe it was 22.5" back from the forward most body mount to the center of the coil bucket. But @tahoverlanding on youtube or instagram makes coil buckets for the swap now and it is much simpler than using the dodge buckets. If you watch his videos you will see why.Pretty awesome. So did the axle coil buckets line up with the gm buckets?
