Builds DINGO
TRAIL TAILOR
Enabler
Supporting Vendor
Redding CA
A few more items off the punch list. Good 4 hour morning.
Designed a fuse block bracket for the LS3, tapped in for CC vent and got the intake set, overflow bottle mounted, got the evap canister, purge valve and evap vent positioned out back by the tank, filled with Dexos Pennzoil full syn oil. Installed TruckLite Military heated LEDs.
J
franklin40
canada
NTAPHSE
Huntersville, NC
Once SMOG is complete
(BOXED ELEMENT CONCEPT)
Ha! I designed that airbox when I worked at Airaid, it was originally for the 4.0L found in Tacomas and 4Runners. Should flow plenty of air for your E-Rod. You can't tell from this pic, but there is a hole on the right side that you can't see. Usually you would use a velocity stack there and connect to the TB. I hope they would include the velocity stack wit the box since it also shows the lid and gaskets. The round opening on the left with the foam gasket sticks through the inner fender to pull cold air. Not sure how this will lay out in your engine bay, but that was the original intent.
TRAIL TAILOR
Enabler
Supporting Vendor
Redding CA
A lot of cool sheet going on in your shop! Looking forward to it!
I never should have sold HAMP.. not a good time being on assignment in TX....
A lot of "SHEET" is about to happen... I may need a trip to Dittmer to relax and just wrench and play... Maybe a catfish or crappie or two.
J
