Hi, first time posting on here. I bought a 1986 FJ60 with 109k miles that spent its whole life on a west texas ranch. It was driven on a bunch of rough roads and has its share of dings but the motor seems to run great and I think oil was changed and things were fixed when they broke but not much else and I don't have any service records. There's a bunch of oil/build up a lot of different places such as the engine top cover seal, engine oil pan seal, at least the front input into the clutch and maybe into the transfer case as well, the steering knuckles and maybe more! Everything seems to be completely stock except for an electric fuel pump. So far I've cleaned up all the leaks pretty good. I'm planning on redoing the suspension and reinstalling an oem mechanical fuel pump. I've got the old belts off since they needed to be replaced.
My question is, other than chasing some of my leaks and replacing all my filters, fluids, plugs, and suspension what else should I be checking / replacing as a preventative measure? I'm mainly interested in strategizing my work so I can avoid taking things in and out as much as possible.
Compression test? Rebuild carb? Check Vacuum?
Thank you!
Thank you!
