Diffrerences in Air Cleaners 77 vs 79/80
Winterville, North Carolina
I have an 77 FJ40 with a newly installed trollhole carb.
I'm looking for an OEM air cleaner, and I found one that is/was for a 79-80 model. Will it work on my 77? If so, are there adapters or spacers that I might need (like the spacer on City Racer web site?). Spacer for '75 to '80 FJ40 2F Carburetor - https://www.cityracerllc.com/products/spacer-for-75-to-80-fj40-2f-carburetor
everything that I see reflects that there must have been a change with the air cleaner in 79 that was relatively significant, but I can't find any specific information on the differences, and whether they are interchangeable in any way.
Thanks
mattressking
10 digits to freedom
Idaho
Not for carb height - no. The reason is because overseas carburetors (such as your Trollhole) did not include the spacer on the carb body for the EGR so it is shorter overall. Either air cleaner will require the spacer with your trollhole. Both air cleaners will work - just depends how original to your year you would like to be and if you need a visual check for smog components. The later air cleaner hose configuration changed for the smog pump, addition of vacuum driven HAI and thermostatic valve for the dizzy vent. Your truck didn't have those items so there's no need for the later air cleaner, but it will work.
JVZii
Atlanta, GA
The 79+ air cleaners are pretty different. if you want the hose and air horn to period correct they have some pretty different shapes.
I always thought the troll hole type carbs were the same size and shape carb as the OEM. But I could be wring.
I have a older style air cleaner I can take a couple of pics of tomorrow if that will help.
Jack
Purpleaction
GOLD Star
FL
I had a troll hole carb on a 79 that I owned. It needed the spacer to work with the original air cleaner
You answered all of my questions. I really appreciate it. Thanks
Jack
I'm not looking for period correct, just looking for functionality. I really appreciate your reply. No need for pictures.
