Differential pinion depth shim for 77 FJ40
Herbou
Dallas
Anyone know of a supplier that has a shim pack for pinion depth adjustment that will give me 0.45mm overall thickness? The shim goes between the outer race of the pinion inner bearing and the differential casing. The OE 90564-70104 shim is discontinued. Alternatively does anyone have two shims of 0.45mm thickness they are willing to part with? I need the same thickness shim for the front and rear diffs? I have the Nitro shim packs that come with the master bearing kit but it does not add up to the 0.0177" required it is either over or under.
