Differences between 74 and 78 gas tanks? (1 Viewer)
Big D
Is there a difference between the two? Size, dimension (sp?), will a 78' tank fit in a 74?
Thanks Guys.
H2o
i think 74 is one of the last years the tank was inside the cab.
brian
lebanon,pa
umm, that would be 1978.
and as a result of that post, your newbie status is going to be extended by 100 additional posts.
they are interchangable. the slightly smaller tank showed up in '73. from that point to late '78 they are the same.
Mace
rock scientist..
Staff member
s-Moderator
Las Vegas
74 to 78 shoudl be identical.
Unless the tank is UNDER the tub (late 78's had these sometimes)
brian
lebanon,pa
while they are the same, you should give a new tank some thought. oem steel tanks are still availible. if you need to save pennies the plastic tanks are 100ish bucks less then the steels............but i (read:i should have) would just save for a new steel tank.
rusty tanks are nothing but headaches......not that i would know..........
H2o
Where do you live? i have a spare 74 tank that leaks, but i have heard of fixing them (in case you want a second tank to fix while the other is in your truck...). i think if you want long term peace of mind, i think buying a new one is teh best solution...
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
