Fellas,
I just changed oil in my diffs and transfer case. I researched the oil types and capacities as well as torque on the plugs, which came from the AMSOIL site. Thought it may help someone else out to consolidate here:
Controlled Slip Differential, Front .....GL-5*
Below -18°C......80W-90, 80W
SAE 80W-90 Synthetic Gear Lube
Severe Gear 75W-90
Severe Gear 75W-110
Standard Differential, Front .....GL-5
All Temps......90
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
Severe Gear 75W-110
Standard Differential, Rear .....GL-5
All Temps......90
Severe Gear 75W-90
Severe Gear 75W-110
Controlled Slip Differential, Rear .....GL-5*
All Temps......90
Severe Gear 75W-90
Severe Gear 75W-110
Transfer Case,.....GL-4
75W-90
Synthetic Manual Transmission and Transaxle Gear Lube 75W-90
Transfer Case,.....GL-5
75W-90
Severe Gear 75W-90
Severe Gear 75W-110
CHASSIS LUBRICATION
6-8 Fittings, 2 Plugs..........LB
Series 2000 Synthetic Racing Grease
Synthetic GHD Heavy-Duty EP Grease
Synthetic Multi-Purpose Grease NLGI #2
CAPACITIES
Engine, with filter..........7.2 quarts[1]
Cooling System, W/ RR HEAT Initial Fill..........16.0 quarts
AMSOIL Antifreeze and Engine Coolant
Cooling System, W/O RR HEAT Initial Fill..........15.0 quarts
Automatic Transmission, A343F Initial Fill..........2.0 quarts[2]
Automatic Transmission, Total Fill
4 speed A343F..........12.0 quarts
Differential, Front..........3.4 pints
Differential, with LDIFF Rear..........6.8 pints
Differential, withO LDIFF Rear..........7.0 pints
Transfer Case,..........2.7 pints
1. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all
gears. Check fluid level in PARK and add fluid as needed.
TORQUES
Oil Drain Plug.....29 ft-lbs
Transfer case
Fill Plug.....27 ft-lbs
Drain Plug.....27 ft-lbs
Severe Gear 75W-90
Severe Gear 75W-110
All Temps......90
Severe Gear 75W-90
Severe Gear 75W-110
All Temps......90
Severe Gear 75W-90
Severe Gear 75W-110
All Temps......90
Severe Gear 75W-90
Severe Gear 75W-110
75W-90
75W-90
Severe Gear 75W-90
Severe Gear 75W-110
CHASSIS LUBRICATION
CAPACITIES
TORQUES
Transfer case
