I need to find the wires for my diff lock
Just the wires.Front, rear, or center diff?
Rear because I didn't have a full exausht on at one point and drove a long trip and my rear diff lock came on so I'm assuming the wires melted because it was hot enough to burn through my tankJust the wires.
Burn through a tank? Huh?Rear because I didn't have a full exausht on at one point and drove a long trip and my rear diff lock came on so I'm assuming the wires melted because it was hot enough to burn through my tank
No, not unless you're using my special gizmo for air lockers. How did that work for you btw?Burn through a tank? Huh?
Hi-Jack on, doesn't the plug below the cruise control servo have both front and rear control wires?
Uh, sure.dude, you're going to...kill me...I'm sure that the lifetime warranty is still good?
dude, you're going to drive over here and kill me. I still haven't installed it. I've been vacillating on what air source to use for the lockers and recently decided to use a Puma instead of the ARB I bought. So now I have to plumb the airlines and I'm thinking of doing the solenoid manifold off the PS fender around the connector area, but wanted to confirm there were both rear and front signals in that harness. Seems like you told me there was.
I'm sure that the lifetime warranty is still good?![]()
Well, the wires for the front one are on the fender right behind the air cleaner
Need the wire colors I lost my harness that connects to the actuator (front diff) to the harness on the passenger side behind the air filter. And I need to make a short harness for that. Any help
