Diff lock leaking
Discussion in '80-Series Tech' started by blu 60, Jul 7, 2005.
  1. blu 60
    blu 60
    54
    Feb 17, 2005
    Texas
    So, I replaced my rear diff lock actuator after discovering that it was very corroded inside, but now I have a leak coming from the area. There are no gaskets on either the actuator to housing or the inspection cover to housing. What permatex type stuff should I use there?
    Any help is greatly appreciated.
    Herman in Houston
  2. RavenTai
    RavenTai
    6,048
    48
    Nov 16, 2003
    Dixie co. Florida
    it was suppose to be sealed sith FIPG when you installed it, any good medium/high temp RTV should do. clean all the surfaces with solvent first, IIRC you will need to drain some of the fluid out of the diff,
  3. blu 60
    blu 60
    54
    Feb 17, 2005
    Texas
    Good, I thought some RTV would do the trick, and yes a bunch of oil has to be drained.
    Herman in Houston :banana:
  4. Jim_Chow
    Jim_Chow
    2,479
    14
    Apr 28, 2003
    Turquoise Trail, N NM
    Blu, how much did the actuator assembly cost? I heard you can only buy the entire assembly (motor, gears, housing), not the individual parts.
    Anyone know if the old 70-series factory cable-operated lockers are compatible w/ newer electric lockers? (ie, can one replace the actuator motor w/ a factory cable?).
  5. blu 60
    blu 60
    54
    Feb 17, 2005
    Texas
    Jim
    $560 from Cruiser Dan just don't forget the RTV sealant like I did!
    Herman :doh:
  6. nyk438
    nyk438
    253
    Jun 23, 2005
    Austin, TX
    What is the RTV stuff? Can I use it to replace the gasket on my fj80 oil pan?
  7. CharlieS
    CharlieS
    631
    39
    Feb 4, 2005
    RTV is Room Temperature Vulcanizing rubber. RTV sealant is used for gasket material. I suppose you could use it for an oil pan, but why do that when you can use an actual gasket?
    Call CDan...
    Charlie
