I'm hoping to hear from mud users who have done a 12H-T swap into a US FJ-60. I've run into a problem with mine.
Here's the scoop. To determine the position of the front motor mounts I bolted up the engine, bell housing, and tranny. I stuffed them in and bolted in the tranny and crossmember. Since the tranny (H55) and bell housing are the same length as the FJ parts, I thought I could use the rear mounting point as the point of reference for the front mounts. Everything seemed to fit so I welded in the front mounts to match.
After I finished my T-case rebuild and reassembled everything, I went to drop it in and it wouldn't fit.
I'm not entirely sure what I did wrong. The engine now bumps the firewall before I can get it back far enough for the front engine mounts to line up. I modified the front mounts to bring the engine forward about 1.5" and now it seems to be in the right place. However, now I need to modify the tranny crossmember and drive shaft lengths.
This is the point where I realized something might not be quite right about this. I don't recal anyone stating that drive shaft mods are required for this swap. Are the HJ-60 (manual) and FJ-60 tranny crossmembers the same?
Is there anyone out there who can confirm?
