Diesel Shutdown question... (1 Viewer)
For those with a diesel conversion (ditch the 2F in a '60, throw in a diesel), how do you control the shutdown of the engine with no ignition to speak of?
Assume that the diesel isn't a Toyota diesel. Is there a fuel cut-off solenoid that's activated?
Thanks for any input.
uberhahn
Panama
on most diesel engines ther is a fuel cut off solenoid .... what engine did you swap?
Donor trucks
I am planning a swap. I've found the '60 I want (1897).
I have also decided on the engine (Isuzu 4BD1T). Should be relativel easy to match to a H55F transmission.
If I purchase a donor truck (usually a delivery / box truck), what should I keep?
What did you do with your donor vehicle once gutted (for those that used donor vehicles)?
Tapage
Club 4X4 Panamá
Panamá
Website
www.4x4panama.com
I thought in things as vaccum pump, I'm not sure in the Isuzu engine, but I believe that comes in the block. Also power steering and alternator ( the alternators in the gas engines comes with more amps ) and for sure keep the wiring from Isuzu truck.
Denver, CO
13B-T has a vacuum shutter that starves the engine of air.
didn't know they made diesels in 1897? lol
I don't know anything about that isuzi motor, but I think keeping it Toyota is better for parts and re sale value (maybe not cost though)
good luck
Possum Lake, Ontario CA
In 1892, Rudolf Diesel was issued a patent for a proposed engine, in which air would be compressed so much that the temperature would far exceed the ignition temperature of the fuel. In 1893, he published a paper describing an engine with combustion within a cylinder, the internal combustion engine. In 1894, he filed for a patent for his new invention, dubbed the diesel engine. His engine was the first that proved that fuel could be ignited without a spark. He operated his first successful engine in 1897. In 1898, Rudolf Diesel was granted patent #608,845 for an "internal combustion engine" the Diesel engine.
