diesel power 1hd-ft
peth
This is the finished result of the week
turbo (landcruiser exhaust supra compressor)
and a shiney intake
14psi of boost
lots of fuel
530 max egt's after turbo ..probs a bit hot ..but ..sooo much power
peth
No air box could stay ,but im modifying it to have a closed top and 3" pipe coming in the side of it with a internal pod filter so i can still use a snorkel .pod is so she is still drivable
when i come into full boost the air filter blockage light was coming on even with a new air filter ,
Tapage
Club 4X4 Panamá
Panamá
Website
www.4x4panama.com
that's pretty normal in my case when I'm boosting more than 14PSI over 3K rpm .. :D
vancouver B.C. Canada
So you are saying the EGT probe is after turbo. If it is then add 100 to 150deg F to those readings for a closer to accurate reading.
Vancouver, Canada
Interesting. I haven't seen that light yet. I can make 16psi from 1800rpm right through to about 2500 but that's when I start running out of air. At 3000rpm I'm usually down to about 12-13psi. Although I'm hoping that problem will be gone after tomorrow... :D
mudgudgeon
Across the pond, and upside down
Your HDJ81 may not have the blocked filter light? My '90 model didnt have it.
good luck with progress Adam, keen to hear how you go :cool:
