Diesel guys
Why are low exhaust gas temps a good thing? Not that I have one, but I'm curious.
Its an excellant indicator of overtaxing the engine. With all that torque it is easy overwork the engine without realizing it. overwork = shorter life
Than why isn't it ever used in the context of ges engines...same principles apply...?
Gas and diesel engines work differently. Excess fuel in a diesel means excess heat which damages the engine. Excess fuel is usually found when the engine is working hard. Sometimes you can see that extra fuel in black exhaust smoke which is unburned diesel fuel.
On a gas engine, as I understand it, excess fuel means less heat so it is not an issue.
The concern of excess EGT's is possible heat damage (cracking and falling into the combustion chamber with catastrophic consequences) to the pre-combustion chambers on an in-direct injected engine (like my 3B) or possible piston and head damage on all diesel engines.
Diesel truck owners with BOMBED motors measure the exhaust gas temps so we know when to back out of the throttle so we don't melt the pistons. Also, another good feature of a pyrometer is to know when to shut off the motor making sure the turbo has cooled down to 300* or less.
With diesel motors, more fuel=more power (to a point where you need a larger turbo to compress more air).
