diesel filler neck part number???
Hello everyone.
I am doing a Cummins repower in my 84 FJ60. The diesel fill neck has a bigger hole for the bigger diesel nozzles at the gas station. My FJ was a gas engine before.
Can someone tell me the Part Number or If someone has a VIN from a FJ60 with a diesel they can share I can look it up at my toyota dealer.
Thanks for any help
Marc
I swapped mine when doing the swap but...there are only a couple spot welds holding the inner neck in place...should not be hard to break free and your good to go
On mine, I just spent some time with a chisel and took out unleaded restricter. DO BE CAREFULL, I later had to take it all apart and seal a small tear in the outer tube. It's not too hard to remove. If you do that you could cut our the insides, clean it up and re-install.
Bob
Try an ad in the classifieds for a used diesel filler tube
like the others say, as I did also, pound it out as it is pretty easy to do.
Daryl
thanks
Good stuff guys.
I will post an add and gently persusde the old one out.
I will have a question about the fuel lines next.
There are 6 lines or more off my tank. WTF?
I was hoping for some news on a supply return and vent.
Take care
Marc
Good stuff guys.
Take care
Marc
The fuel tubes are easy to change ,at least on a 70 series.
As for the supply line,the FJ60 should have 3 lines to the engine bay ,one to the fuel pump,one as a return back to the tank and one to the charcoal filter for venting.
Diesels only have two so you just block/remove the vent line.
Some diesels send the excess fuel back to the filter instead of the tank so check to see what the cummins does.
Ignore the 6 lines on the tank,they mostly go round in circles so its really 3 lines:D
The guys up at Radd Cruisers bouth a new one for my truck. You might contact them.
What's the diameter required for the opening? I haven't gotten to that part on mine yet.
