Did you replace pistons on a 3b? (1 Viewer)
Seattle
I like to know if you did this to your 3b. Did you use a ridge reamer and hone? how many miles on 3b? mine has a slight oil smoking issue and the compression is low on one cylinder.
I have done lots of engine and short/long block changes in the past so know engine repair. BTW precups need to be chained or replaced? original engine from 1984 with 450k on odo.
FJBen
Northern Colorado
Personally, if you are going this far, I would just replace everything and do a full rebuild with machine work. Get everything into spec.
you should have sleeves on that 3b.
I rebuilt a 13bt a couple years ago and went new sleeves, pistons, bearings and polished/grind crank and cam, shaved block, set counterbore and did it all.
It’s not that much more work to pull it all out and get it all sorted.
