Did Slee change the design of his rear bumper jerry can rack?
I know you said no $$$ coolers, but the Yeti size that fits is 35 qt, just fyi
(Found on Slee's FB page)
There are a couple knock offs out there for cheaper,....unfortunately, it appears that RTIC doesn't offer a 35 yet.
The Igloo 48 qt cube fits, with room to spare. The Coleman 48 Can Party stacker, might fit...
I saw another pic of someone using an Igloo rolling cooler in their rack, but it was BIOR.
I used a 20% off coupon at a local store, and after $3k for the bumper and options, $240 didn't seem that bad....
Igloo is 17x17 (no bueno)
carrier basket is - 21.5" x 14.4"
Not Yeti grade nor insulation but perhaps fits the bill. Available with optional rod holders and even live baitwell option!
https://www.buyengelcoolers.com/30-quart-ultra-cool-dry-box-p/uc30-cooler.htm
Btw, I would not trust any manufacturers capacity specs for fridges and coolers.
Reviving an old thread here, but I was googling for a use for my new Slee-Jerrycan basket (wife kindly gave it to me for Christmas) and I came across this thread. I created a similar thread in the 200 forum here in Ih8mud but seeing this thread, perhaps you guys have already found the solution I seek?
@Nottajeep , did you ever find that perfect cargo box that would fit in the jerry-can basket?
I have the yeti 35G cooler and it fits well, but it has two problems:
1. It's expensive so I worry this makes it a target for theives even if I keep it empty.
2. Becuase it's a yeti, it has very thick walls which take away from internal space. (I would use it more as storage than as a cooler)
The Coleman Marine fits pretty well if I recall correctly.
Problem is it doesn't keep anything very cold without adding ice regularly.
Hmmm… the Coleman Marine 52Quart seems like the most likely candidate, but its width is listed as 25”. So I fear it might be too wide.
There is a taper…. But does that taper take off 3.5”? From the pictures, it doesn’t look like the taper is that large.
So I wonder if Coleman has changed the design.
But the suggestion is great though! I appreciate it. It has given me the idea of heading over to Academy (sports store) with my tape-measure to see if:
1. They have the Coleman Marine in stock for me to measure.
2. If there are any other coolers they have that will fit my need.
Thanks!
