Did I install SLEE brake lines correctly?
Emeryville, CA
Installed stainless slee kit, stock height though so maybe this is why it looks like this?
When I took off I saw a short and long hose, I tried to do the same when installing the slee. Did I mix them up by accident or is the brake line in the photo the longer one?
Saw that this hose is slightly touching the rear dif. Did I mix up the short and long line or is this not a problem and all looks ok?
Rubbing a brake hose on any moving part is no good. There is one hexagonal shaped mating surface at one-end of a hose that goes to a mounting ear closer to the gas tank and cannot be interchanges with the other hose coming off of the body to the rear axle.
Just zip-tie it away from the diff.
