I unplugged everything in my driver's rear panel so I could install a set of 80 shoulder belts (which works nicely, by the way...pics later), because cutting is involved and my old panel had a hole in it for the harness to run through. When I reconnected everything, my tail lights were out, instrument cluster illumination was out and fuel level gauge was pegged high. The fuse was blown. Replaced it twice, blew in 2 seconds. Brake lights work.
Hmmm... Turns out, the fuel level sender plug was unplugged (it is hidden under the bottle jack holster thingy...which I have now removed and set aside, since my lift renders a regular bottle jack useless) and the plug to it on the harness was plugged into some other thing (why have adjacent connectors of the same size and type, man?!) that is apparently unused in my 62 (can't be a CD changer, maybe part of the rear A/C or third row seats available in other markets???). I plugged things back together, correctly this time.
Well, now my tail lights and cluster work normally, but my fuel level gauge is dead on E, and I know I have at least a half-tank. I double checked the sender plug, seated fine, even checked the plug on the sender itself (through the little floorboard access panel). Still no workie. Then, I broke down and replaced the gauge (I am a total champ at taking my instrument cluster out, disassembled, and reassembled in record time, did it so many times)...
No dice.
Sender on the tank is fried, huh? Gotta drop my tank to replace it huh? Life sucks, huh?
No dice.
