Figured i'd try to save some time and post once on a few issues. Any help is much appreciated and earns you a beer if you're local to ATX.
1985 FJ60
Manual w/OD
Chevy 400 small block
1 - When turning hard especially if clutch disengaged, I get a big Thunk, Thunk, Thunk, Thunk. I'm guessing CV joint, no? Pretty sure it's both sides but seems to be worse when turning left.
2 - Intermittent very soft braking. Cold/hot, doesn't seem to matter. Happens rarely but enough to notice. The pedal will simply go almost all the way to the floor. Pumping seems to rebuild pressure. Most of the time it stops like a champ. Had master replaced. No problems for a few weeks. Back again. Not losing any fluid at all. Thoughts?
3 - Here's a fun one. Blinkers work most of the time but occasionally just decide to make a constant buzzing sound when engaged and not work at all. Almost like they're not clicking but stuck. Relay? Signal switch itself? Where to start?
1985 FJ60
Manual w/OD
