- Thread starter
- #21
isn't that an air filter in those first two pics? Sorry I'm a neophyteMight want to add an air filter to that valve cover
No problem - this forum is a great place to learn. It is where I learned everything. In your third pic (showing the top view), just above where the red meets the black wire, you will see a opening in your valve cover. This is a direct opening to your valves. On the stock original setup, there would have been a hose from your air filter housing on top on your original carb to that opening to filter air into the valve cover. By switching to a Weber carb (which also has an air filter to filter air into the carb), you need to cap that inlet port to keep debris from getting in. The link I posted is a perfect fit for that inlet. I used it in my ‘70.isn't that an air filter in those first two pics? Sorry I'm a neophyte
Oh I see. Yes thank you!
