Detroit Locker - What if question?
If a guy had a full floater rear with hubs and a detroit locker. Could he run down the highway when it was slick in front wheel drive via the rear hubs free?
Thanks
-Wyo
Howdy! Yes, but you could also do it with out a Detroit Locker. John
The rear hubs aren't "locking hubs" like the fronts. No unlocking them.
You could drive down the highway just fine, it's the turning when you can spin a tire. I *think*, with an auto locker, you're ok as long as you don't accelerate while turning, but you can coast or hold your speed and it won't lock the locker. Somebody will correct me I'm sure.
:beer:
"The rear hubs aren't "locking hubs" like the fronts"
With a full floater and hubs on the back you could unlock them just like the front I believe. I was wondering if it had any adverse effect on the drivetrain running at high speed that way.
Thanks
-Wyo
True, however I'd like to pull my 60 with a tow bar and not disconnect my drive shaft. I have a detroit in the back of my F250 and get along fine in the winter, but I'm always a little more worried when on the ice. When you look at the cost of a ARB locker and compressor, a detroit/full floater isn't that much more expensive. The hubs busting is a concern however with the added stress of the locker.
Thanks
-Wyo
I din't catch the idea .. it's running on one rear wheel traction or only front traction with both rear hubs unlocked ?
Ok let me rephrase, maybe I don't know what the hell I'm talking about.
If you have a full floater rear axle you can put selectable hubs on the rear like the front, correct?
Ok, now if you have the rear on "free" free wheeling and the fronts locked in, you will be running with front wheel drive as the rears is free wheeling.
Now, can you travel at a high rate of speed the fronts locked and the rear hubs free?
Forget the Detroit locker for now.
Thanks
-Wyo
"Only if you have custom axle shafts made that have splines on both ends...."
Well there is the first glitch in my plan, that sounds expensive.
Thanks
Wyo
Howdy! Yes, this setup has been done before. I think the owner was looking at being able to flat tow it by just putting all 4 hubs in "FREE". Yes, you could drive it on the hiway in front wheel drive only, by putting the rear hubs in "FREE". I don't think it would cause a problem, as the axles and wheels would still be turning at the same speed, but they would not be connected. As long as both hubs on the axle are in "FREE", I don't see how any style of diff lock would make any difference.
The interesting part is that the rear axle shafts and the tires would still be turning at the same RPM :)
I'm afraid to ask, but to the few people who know what I'm talking about, would gas millage suffer from running this way? Or would it stay the same about the same.....
I imagine it would be like running with your front hubs free yet in 4wd, maybe even more as you are spinning a longer drive shaft etc.
Submiting reply; shaking.
-Wyo
-Wyo
You are concerned about mileage and own an FJ60?
:lol: :lol: :lol:
I cannot see a reason why it would increase.....
Well if I'm only getting 13 and if I have to drive across Wyoming on the Ice and only get 6 because I'm rotating things like a detroit locker for no gain, then yes, it may change my plans some..
Thanks
-Wyo
Since someone mentioned flat towing a 60. What kind of damage can flat towing cause if you don't remove the rear driveshaft?
I've towed my 40 for thousands of miles with the driveshaft in place without incident. Or I'm I just asking for trouble down the road sort of speak.
you said in your first post about doing this(FWD) on a slick road. I would guess that engine braking would would cause the front tires to brake traction. in the ice = no good
just a guess
