desmog is getting there
i do not have a welder so i used a plug for the egr/pcv contraption on the exhaust manifold.
found plug at lowes in plumbing section, threaded metal pipe end plug:
3/4" black plug, part 36660 70704, southland products, $0.70
now i have to figure out how to plug the exhaust return from near cat (would return to air switching valve assembly), maybe order a sor plate for the exhaust pipe from under the manifold (one going to exhaust cooler which is not there anymore)
as is, the cruiser has 3 exhaust pipes, one off the manifold (going to cooler), one off before the cat, and the factory exhaust. cruiser has an interesting sound when running, almost sounds like a chopper.
if i cannot figure out a good fix, i might have the exhast down tube cut before return and have a Cherry Bomb Glasspack welded on.
If you manufacture a block-off plate of 3/16 or 1/4 " steel and attach to exhaust manifold with new gasket and copper based spray, you can totally remove the cooler mounted to the block.
The intake manifold can also be blocked with a similar plate, but you may need a 3/8 inch pipe welded in to take care of PCV hose connection.
The third pipe, which should come into the engine compartment below the brake master cylinder can be blocked with a penny and then filled with JB Weld...or, you have to crimp lower down and weld shut.
the cooler has been removed from block, the pipe from the exhaust manifold is left. sor sells a block off plate for 8 bucks i think, its on thier header page.
the intake/pcv/egr i used the original part, just where it connected to the egr via a nut i used the plug listed above (there is a good write up here where someone took off and cut and welded a plug).
the 3rd pipe seems to be a problems and i might use your penny jb weld idea, got to look at it some more.
maybe connect the pipe from exhaust manifold to pipe from cat area? wonder if that would create some odd pressure problem?
desmog
glad to see it coming along well brotha, but as far as exhaust why dont you just get headers ? wont they be less complex and better suited 4 a desmog appl. ?
also as far as carbs go are you staying stock or going with a non usa asian carb? same with dizzy non usa? seems like that they will work well with a desmog set up. just my 2cents :bounce2:
i am thinking about going with headers. not sure which one to use, i read in a few post that the 2 piece is the prefered.
i have been driving it around as shown above. no vac lines hooked up, just to get a feel for how the engine reacts to all that smog crap removed. i think the carb is not the original, but is stock and i am going to stay with that. and i am not sure on the dizzy yet.
the engine has been running great, it seems that it responds to the throttle a little quicker. and now it will idle below 700. with smog stuff it would die below 1000 rpms. I tried replacing all vac lines, new vcv's, new bvsv's etc..... nothing helped.
If you have oe mufler with three bolt connection cut off the pipe. Use brackets to hold new piece on the pipe couple spots of jb on it and take the piece to your local muffler shop 10 bucks for the weld and take brackets off. use oe setup for cat and muffler. install w/ brackets and mark location. do most welding off truck. I used brass as my block off plates (easy to cut/drill). i threw the polish on for extra bling. will post pics soon.....Brass and steel have similar temps. so I don't think there will be a problem. What did you plug your air inj man with?M14x1.5 I think. :beer:
