Okay well I dented my inner axle seal while installing it. Not sure if that's a first but I managed to do it. Should I run as is, try to bend dent out and use, or order a new one?
New one. What were you using to install it?
Someone really needs to make a dedicated tool to prevent this from happening.
You're f'n shameless, you know that don't you...Someone really needs to make a dedicated tool to prevent this from happening.
Approximately 10 seconds after I realized I dented it, I said to myself, "Yep, should have bought the thing".
Lol. I should report your post for smart-assery.Someone really needs to make a dedicated tool to prevent this from happening.
Just to verify
90310-35010
is correct part # correct?
I'll say it for NLXTACY: The Wits End seal driver pushes the OEM seal a bit deeper than regular seal installers, so the lips of the new seal don't ride in the same place (or groove) as the prior seal(s), which helps prevent premature leaks.
80 Series Inner Axle Seal Offset Driver
80 Series Inner Axle Seal Offset Driver (ASD-1)absolute-wits-end.com
BTW, where can I find that poster??
