Only a Real OEM Toyota or OEM DENSO Starter will have this RED and SILVER Foil Decal on it
That's it...thanks. Looks like my next project. Easy, cheap and may help. We will see.
Will someone just buy a starter already?
None of this is rocket science.
Definitely not trying to short sale the guy making these cables because they look hella quality but you can easily make all of these cables. Get yourself a battery crimper, some 1/0 welding cable, heat shrink tubing and some battery connectors and there you go. I invested in a good pair of crimpers along with some quality wire and have slowly been upgrading the cables in my truck. I still need to redo the starter cables and some of the grounding. Plus its kinda fun to upgrade the old wiring IMO. haha. I have also been adding more fuse blocks and electronics so I'm doing a bit more extensive wiring. Anyways just my 2 cents.That's it...thanks. Looks like my next project. Easy, cheap and may help. We will see.
Thanks for the connector and terminal @RAGINGMATT
Worked perfectly.
View attachment 1888684 View attachment 1888685 View attachment 1888686 View attachment 1888687 View attachment 1888688
I have more $ than time....ordered them and debating even putting them on myself.While true, I did not have all the crimpers and cutters needed to make these cables. I priced the tools and cable/ends out online and by the time I purchased all that I would be closing in on the cost of the cable set anyways. So I opted to let someone else do the work. The next time these cables will need to be replaced, someone else other than me will be doing it. @Fourrunner is good people and I am always good with helping out a fellow mudder.
