I've collected this entire thread into a PDF. Here's the link:
Definitive list of AHC maintenance items from IH8MUD Forum.pdf -
371 pages. definitely more pages than the Boeing 737 MAX manual.
Driver | Passenger | |
Front | 19 1/2 " | 19 5/8 " |
Rear | 20 1/4 " | 20 5/8 " |
Reading (MPa) | 1 | 2 | 3 |
Front pressure | 6.9 | 7.1 | 7.1 |
Rear pressure | 6.9 | 7.0 | 7.0 |
If pressure and heights are within specs, the 7 ticks means time to change globes.
Without checking heights and pressures, the tickmarks mean next to nothing.
As uHu says, pressures and height readings from techstream must be taken in context and referenced back to the physical height of the vehicle as per the FSM if you want to dial everything in for stock height at stock weight.
If my pressures are close (when I read the pressures before the AHC change, it appeared that new rear springs and a few twists of the torsion bolt would bring me in spec), is a failure of the graduation test *guaranteed* to be failed globes?
Would the 16-step test be more definitive? I think I'm going to replace all four if even only one of them is bad, but would like to be reasonably sure that that's the issue before dropping these $$$. [Add: Trying to beat the government's proposed 25% tariff on these items - could happen as early as May.]
Springs are a given.
The damper accumulators naturally degrade over time via gas permeation and this is evidenced by the diminishing L to H graduations check. What you’re reading when you count the graduations is the combined volume displacement of the four shock actuators stroking (which will be a constant for the same L to H travel) and the fluid expelled from the four damper accumulators as the preload (neutral) pressure goes from a lower value (in L) to a higher value (in H). The variable is the gas charge in the accumulators and it is a generalized indicator: it can’t single out a better globe from a lesser globe. When you do the 16 step test that “should” identify a particular corner that feels different, ie harder, to the others. But it’s a bit subjective too. You should do both tests on the understanding that overall globe/damping performance and degradation is roughly linear until, or if, it ruptures.Bumping this and hoping for some advice before pulling the trigger on new globes:
* Ride is "floaty". Turns are not as tight since flushing AHC.
* Expecting new VCI cable to arrive tomorrow.
....Suspension feels loose after stopping. It rocks back and forth with oscillation movement till it holds still.
Here is a video shot from outside the car. Notice the oscillation after every stop. This was during step test at step 16 so the vibration was very obvious from outside. At step 1 it’s still there but could only be felt inside the car.
What do you think this might be?
May be the video is not expressing the issue fully but you can certainly feel the vibration / oscillation inside the truck. It rocks back and forth for 4-5 times till it holds still.I think you are chasing windmills. That looks like normal movement in the tires and other rubber components. Change to all steel tires/wheels and exchange all rubber bushings with ball bearings, and you'll get rid of it..
Yes I did and tightened them. No effect.@Castamile have you checked your front hub Barings? possibly need to be tightened
I had Slee put an old man emu 2 1/2 inch lift on my 100 series LX along with sliders on my 100 series LX 470 the AHC suspension system is not as robust as a 200 seriesMay be the video is not expressing the issue fully but you can certainly feel the vibration / oscillation inside the truck. It rocks back and forth for 4-5 times till it holds still.
The reason I don’t think it’s normal because I had the opportunity to compare with another lx same year same miles ( even same color)and the ride was so much different. I suspected the globes, when I swapped them to confirm there was no difference in either trucks.
I will try replacing front control arm bushings and ball joints and see if that makes a difference.
You have some reading to do. Start at the beginning. It's just too much to write in one single post, and since all you need is covered here already...Haha, I'm pulling my hair.. I must be the only one ever with this problem, but No matter how much I (dis)crank the TB's, they don't change the height (and right-left lean) at all.. Altough I'm doing it on the ground as I don't have a lift - could that be a problem?
I did go through roughly earlier and didn’t seem to find out why my ahc is behaving as it is - unlike others, but I’ll go through the thread again![]()
I collected my favorite pearls of wisdom here:
So I am happy that my heights are adjusted, and pressures are now w/in spec for F & R, but still want to know about adjusting the height sensors. For the rear, it looks like only one adjustment at the slider. For the front, it looks there are 3 different opportunities to adjust - the big slider...forum.ih8mud.com
Hopefully that can help you!
