Not sure I understand that. Did you mean it is $600 for the original alternator job plus now an extra $1300 for the timing belt and related accessories job? Cuz if so, the latter does not seem much cheaper than a normal timing belt job at full cost from what I recall (although what I'm thinking of does not include seal work typically IIRC). If I'm right (not sure), that's great if it makes your life easier but doesn't seem like a great bargain either. And it takes some balls to have the same place do even more work on your truck. At least make sure it's not the same tech cuz he probably isn't happy right now - and we already know how good he is...
On a related note, I just watched a video on timing belt replacement on YT and one of the first things the guy says is to watch out for that alternator bolt as it is prone to snapping off. Must be a common occurrence (and something a good Toyota tech should know).
added: if you would like a feel for the cost of parts on a TB job, here is a list off amazon, mostly OEM or equivalent :
That site also has a great vid on timing belt replacement with the engine *out of the truck*, very nice to see. It's the *updated* vid series.
Auto Repair Bealeton VA - Mechanic Near Me - Oil Change
Full Service Auto Repair in Bealeton VA, Specializing in Oil Changes, Brakes, Engines, Transmissions, Tires, Auto Maintenance, & More.
www.otramm.com
