Dead battery....again???
Central Florida
I haven't had a problem with this until recently - went out the other day after aroung 8 days of not starting the pig....nothing, not even a click. Throw on the booster, starts up fine. I let it run for an hour or so at aroung 1000rpm's. After that, no problem. I use it all weekend, no problems. Go to start it tonight....nothing.
Battery is less than a month old. Mind you, I just installed a MG alternator - and the amp gauge reads that it's charging well - as does a battery meter. I popped off the caps on the battery - water is a little low, but not too bad.
Is this a coincidnece - or could the MG somehow be draining the juice from the battery? I have it hooked up through the stock wiring, as well as a #2 ga marine battery cable to a 200 amp mega fuse direct from the post on the back of the MG to the + of the battery.
I'm stumped here??? :confused: Bad battery or a drain somewhere - no, nothing is on inside the truck either. Is there a way to check if something is draining the battery? Cold this somehow be a short? If it is, how would you even detect it?
This may help. It may be a coincidence that the booster helped. Check the terminal clamps on your battery and make sure they are getting a good connection, and check main lead from the battery. Mine looked fine but the cable had corroded and there was actually no wire touching the connector... just corrosion.
good luck
Chris
I second the corrosion issue. i have an 82 fj40 so it is all setup kinda similar. just this last weekend my battery wasnt recharging at all. the terminals were covered in blue corrosion. clean them off with baking soda and water. worked perfect after that. worth a try.
FSU - I believe that the MG has an internal regulator. Everything is hooked up EXACTLY the same as it was - with the exception of a brand new cable running from the alternator post to the + of the battery.
Doughbuy and C-Head: The main battery cables look "okay" - not perfect, but not too terrible eirther. Unless the other thin wires are crapping out. I did notice that the positive lead clamp on the battery terminal is looking pretty rough - but not corroded. It seemed like it was charging fine - as it ran all weekend and started after letting it run for an hour. I put a meter on the battery tonight and it read somewhere around 8 volts.
Not sure even how to test this. Could it be a bad battery?
The only thing tha tI can think of is that by connecting the post on the alternator directly to the battery, somehow it is completing a slow drain circut - like a possible gauge or something. I'm starting to wonder if I put a (not sure what size) amp diode between the alternator and the battery terminal that may solve the problem.
I have not changed anything in the rig since owning it except the alternator - and that is somewhere around when the problem started.
It has to be something to do with the direct lead from the alternator to the battery. I just don't know how to diagnose it.
Had the same problem. After I made sure my battery and alternator were fine and wired correctly I was stumped. THen this one armed guy I told me to change the terminal clamps. I changed the clamps and she started like a champ and has started every time since. That one armed guy new his shyt. Hope this will help you. good luck
Patrick
I thought my batt. was dead, turned out one clamp was not making enough contact. I took it off, roughed it up with some emery paper as well as the terminal, put it back, good to go.
And make absolutely sure the alt. has an internal voltage regulator, because not having one would result in poor recharging.
Maybe you have a drain somewhere, but I'd make sure of the above two things first.
When I put a voltage meter on the battery, it read 3.4 volts - so the battery is dead. When I asked if the MG alternator had in internal voltage regulator, they said yes. When I had the engine running - it charged well. I was able to use it all weekend with no other problems, so I know that it's charging - there must be a drain somewhere - but how would I find it?
I don't have any help to offer, just sympathy. I'm going through similar things with my 62. I've already replaced the battery. All I know is that something is drawing off of the battery.
There's a device you can use that lights up when you touch it to the battery, if you have a draw. Unfortunately I don't know what it's called. After that, I don't know how you go about determining where it's coming from. My two main suspects: the alarm and the stereo.
Also, my buddy found that there's a short in my wiring. I don't know if that's related. He used another thing and touched it to the socket for my turn signal bulb (that's what we were trying to fix) and by the pattern of the beeps, he said there was a short.
But that was the extent of his expertise, so I have to take it to a shop where they can track it down and fix it.
I really should pay attention more to what they're doing when they're fixing my rig, rather than playing with the kittens and making sure everyone has beer. :o
I can't see that the stereo can draw that much power when it's off - second, I must have a short somewhere. It's just a question of finding it...
Blue Chip,
What someone recommended earlier was place an ammeter to see how much current you are drawing when off. If too high (more than a few hundered milliamps), then remove the fuses one at a time to see when the current draw disappears.
